Sub mounting depth
I was wondering if anyone knew what the mounting depth for the factory sub is?
Depends on the sub,
https://i.ytimg.com/vi/lyxPKIkUSuo/maxresdefault.jpg But seriously I've never had mine apart |
Another curious question: LS models with the sub knock-out - is it simply pre-wired for plug & play or do you have to run wire to radio from scratch?
You would have to look. I doubt the wiring is there, but it might be.
if you want it to look factory, then you can only use a shallow sub.
Or you can put a box back there or build a custom box and fit it in the wheel well..which i was thinking of doing a while back. regarding the wiring, mine didnt have any wiring back there |
Originally Posted by skyline26
(Post 826241)
My LS has the Pioneer system with the sub, you must be thinking cars that didn't have the Pioneer system option
Originally Posted by Squiirl421
(Post 825994)
Originally Posted by Oldblue
(Post 826274)
As I mentioned in the other thread, a parts yard or try Crutchfield
| All times are GMT -5. The time now is 03:25 AM. |
