Timing Chain Guide Bolt
Old Sep 30, 2020 | 03:05 PM
PulpFriction's Avatar
Originally Posted by fastsuv
I've done a few of these, but always with no tension on the chain.
I would be afraid the guide would move sideways from the chain tension and you wouldn't have any way to align it.
It might be better to remove the tensioner and then replace the bolt.
Steve
That was my concern. The valve cover is off and from the top I can see a slight deflection in the chain that I expect would shift the guide over a tiny bit once the bolt is out. But because the cover is off, I should be able to stick something in there push the guide back into place to get the redesigned guide bolt in.
Re Old Blue‘s comment, yep, the chains are now an urgent priority but I need to get the car to a shop, because, well, several excuses for not just doing it here. Will slap the valve cover back on and baby it for one trip. Was thinking maybe in case that guide broke down further, the new bolt would be more likely to survive than the old one. As long as I don’t drop the bolt.
Maybe I’ll flip a coin.
Old Sep 30, 2020 | 03:11 PM
Originally Posted by Oldblue
Thanks! Though I had already seen that, but this seems to be a newer version.
Old Sep 30, 2020 | 04:12 PM
Don’t drive that one more trip, change the chain, it’s not really that hard! I’m 66 and it takes me about 3 hours with hand tools , I only jack up the passenger side and put a jack stand under it.
Old Sep 30, 2020 | 04:30 PM
Russian roulette, anyone?
Old Oct 1, 2020 | 06:51 PM
I’m definitely not going to change the cam sprockets (VVT), and would rather not change the crank sprocket if it looks good. Is it possible to get the chain off and on without removing any sprockets?
Which if any new gaskets are mandatory? I was kind of assuming the valve cover.
Old Oct 2, 2020 | 07:01 AM
You have to remove the cam sprockets, in order to remove the chain, I’ve reused the front cover and the valve cover gaskets, just be careful and gently wipe any oil residue from them . There is a kit from Cloyes that does not include the cam sprockets or the crankshaft sprockets. 9-4201SX
Old Oct 2, 2020 | 10:38 AM
Off to find some Cam sprocket bolts GM 11588844
Old Oct 2, 2020 | 11:52 AM
Try RockAuto, but you can reuse those
Old Oct 2, 2020 | 05:13 PM
Only need to remove the exhaust sprocket. All VVT engines have the "new" hydraulic tensioner.
Old Oct 2, 2020 | 05:21 PM
I found it very tight to get the chain around the intake phaser and sprocket, so I removed that bolt also.
The bolts are thick and will stand up to reuse, once or twice.
