Timing Chain Guide Bolt
Re Old Blue‘s comment, yep, the chains are now an urgent priority but I need to get the car to a shop, because, well, several excuses for not just doing it here. Will slap the valve cover back on and baby it for one trip. Was thinking maybe in case that guide broke down further, the new bolt would be more likely to survive than the old one. As long as I don’t drop the bolt.
Maybe I’ll flip a coin.
Don’t drive that one more trip, change the chain, it’s not really that hard! I’m 66 and it takes me about 3 hours with hand tools , I only jack up the passenger side and put a jack stand under it.
I’m definitely not going to change the cam sprockets (VVT), and would rather not change the crank sprocket if it looks good. Is it possible to get the chain off and on without removing any sprockets?
Which if any new gaskets are mandatory? I was kind of assuming the valve cover.
You have to remove the cam sprockets, in order to remove the chain, I’ve reused the front cover and the valve cover gaskets, just be careful and gently wipe any oil residue from them . There is a kit from Cloyes that does not include the cam sprockets or the crankshaft sprockets. 9-4201SX
