tire size needed
Old Aug 24, 2022 | 03:29 PM
Basically the limiting factor is the tire height, the top of the tire is very close to the bottom spring support of the front struts. Anything larger than stock will hit it.
Changing the offset can screw the geometry up; that means dangerous handling and bad tire wear.
If you are not going to drive the car you can put anything you can force under the wheel arch on.
PulpFriction
Tires & Wheels
12
Oct 27, 2022 07:25 PM
Crazy Canuck
Aug 16, 2013 09:42 PM
Canesfinsfan83
Tires & Wheels
Feb 8, 2012 05:50 AM
RBodeman
Tires & Wheels
Nov 25, 2011 06:28 PM
1_FAST_SS
Nov 4, 2010 12:31 AM
