Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   Towing A Five Speed Manual Front Wheel Drive Hhr (https://www.chevyhhr.net/forums/general-hhr-4/towing-five-speed-manual-front-wheel-drive-hhr-7648/)
baldeagle31840 Apr 11, 2007 05:12 PM
Can A Hhr With The Five Speed Manual Be Towed Behind A Rv With Out Any Modifications. I Know On A Rear Wheed Drive Just Put It In Nutral And Tow. But I Do Not Know If The Same Is True For A Front Wheel Drive Such As The Hhr. The Dealer Service Dept Did Not Know For Sure, Where Can I Get This Information.
Thanks
HillsdaleHHR Apr 11, 2007 05:15 PM
1 Attachment(s)
Attachment 41909 to the site!!! Owner manual states that it can be Dinghy towed (all 4 wheels on the ground)!
1. Set the parking brake
2. Turn the ignition key to ACC to unlock the steering wheel
3. Shift your transaxle to Neutral
4. Release the parking brake
HillsdaleHHR Apr 11, 2007 05:33 PM
Forgot this part
Important note: To prevent battery from draining while the vehicle is being towed, remove the following fuse from the floor console fuse block: 8 (Ignition Switch, Pass Key III) Remember to reinstall the fuse once you have reached your destination.
Never exceed 65mph while towing your vehicle.
