Towing Question
I tow my HHR behind a motor home. In order to do this I have to pull the #8 fuse from the inside fuse panel. Is there a better resolve than to stand on my head and pull this fuse and then do the same to put it back in service. I would certainly appreciate any input.
Yes, I installed a switch, which makes it a lot easier. I think there are several avaiable, but mine came from: http://www.rv-partsplus.com/home/accessories/
Meanwhile, while you are still pulling the fuse, just leave the fuse puller on the fuse, makes it a lot easier to identify fuse 8. |
