Trans acted weird
Old Feb 17, 2025 | 03:11 PM
Bonez's Avatar
Originally Posted by WoodysMobile
Load test the battery and the other routine checks we all know of reading/posting here.
Spring is coming the warmer weather cures much and keep on going!?
You didn't mention age/mileage but sooner or later stuff happens to everything.
Good day/ week...
175K + on the Odo
Old Feb 17, 2025 | 03:13 PM
Bonez's Avatar
Originally Posted by Oldblue
Could be solenoids, cracked fluid transfer pipes, loose ground wire, loose fuse box bolts, or TCM connection.
Hopefully not, been planning a trip soon , love the MPGs for those long trips. It would really suck if it rolled over because I want to get back into a truck.
Old Feb 17, 2025 | 04:01 PM
I found this to test your battery
Or just go to you local parts palace
Old Feb 17, 2025 | 11:07 PM
Bonez's Avatar
https://youtu.be/gq0iey9VC94?si=_iarFpA6evtfDP5V
Yes Ive done this with the 08 before. I had a battery at one time that when you stuck the multi meter on it you could just watch the voltage drop.
Currently, I can start and shut the car off multiple times and it still has the instant start up as it barely cranks and fires every time... so I doubt the battery is bad or close BUT Ill have to test it to know for sure with the meter or at the auto parts store.
Hasnt done anything since but we are about ready to get hammered with almost a foot of snow so ill be stuck at home until the snow melts off my drive again probly a week as temps are dipping to the Negs by mid week and next week into the 60s... Crazy Misery, I mean Missouri weather.
Old Feb 18, 2025 | 08:00 AM
PulpFriction's Avatar
Yeah, but really, how hard is it to poke the two Volt meter probes across the posts? The hardest work is taking the cover off the donut well. Oh, wait! You can do it under the hood!
MindDrive
Oct 19, 2015 06:33 AM
jdzialak
Aug 21, 2010 08:22 AM
masterchief1112
May 7, 2009 10:07 AM
esmarkey
Jan 29, 2009 02:34 PM
Lee3333
Aug 30, 2006 09:08 PM
