Trans question HHR
There is much more slack (wheel movement) on driver side than pass side, could the drive chain inside the trans be the problem, or is this normal? I thought it could be the CV axle but the loss motion seems to be inside the trans. 2006/2.2/ auto.
Thanks...Bill |
It never occurred to me to check. I don't know where exactly the park pawl is, that could be what you are seeing.
You might see it in here!
HA Oldblue when I first saw that episode I got way more excited than I should have to see the camera pan out and reveal an HHR!
Buried at the very end, I think is the answer. The one side is "drive" the other side is "driven".
I have never heard of a drive chain wearing out. If it was any wear issue it would be in the differential part. |
1 Attachment(s)
It's got to be the CV, the park pawl locks the shaft that drives both wheels, also answered the question, can the drive chain be replaced without disassembling trans. #13 is the park pawl. DOMBREW, all the slack is on the drive/chain side, the dif/spider side has normal movement..Bill
