Transmission sleeve bearing passenger side…
It won’t fix much , to answer your question question , yes you can.
I installed a repair kit to stabilize the stub shaft
this kit from Fitzall
https://www.fitzall.com/supportDetail.php?14125RB-298
?….guess I dont understand how it works. I did replace stub axle seal several months ago and know how they built it…even though I dont know why they even used a stub axle instead of making that part of the cv axle….be 1 less joint.
so how does it stabilize it?
Really I am wondering how badly worn the sleeve bushing is pressed into the housing inboard of the stub axle and if it can be replaced without disassembling the transmission?
There are pullers for the task, but the new sleeve bushing won’t support the stub shaft. The kit has a bearing you install in place of the cup then a seal in that .
I think I posted about it
https://www.chevyhhr.net/forums/driv...g-again-66133/
There’s information about Detroit Axle
https://www.chevyhhr.net/forums/driv...mission-66019/
jbiesent
44
May 9, 2016 12:11 PM
