Under Hood Light Installed
Old Oct 6, 2006 | 06:37 PM
RUDEINC's Avatar
I finally got tired of chasing after a flashlight every time I needed to check something under the hood, and being as how GM "forgot" to install an under the hood light on my car.......Viola....
The nice thing about this light is the bulb is detachable, and has 20 ft. of extension cord. The bulb also has a suction cup or a magnet to use so you can mount it to any surface on the vehicle. Another nice feature is the on/off switch. Easy 2 wire hookup (12v from battery and ground). Although I wired mine to an extra hood pin switch from an old alarm install, so when you pop the hood the light automatically comes on and when you close the hood the light goes off. But if you are at a show or need to leave to hood open for an extended period of time, you can just switch the light to the off position on the switch and save your battery power. These are actually OEM on 93-98Grand Cherokees.
Mounts very well on the core support....
The wiring and pin switch.....I also used wire looms to create the factory look..
In operation......
Regards.............
Old Oct 6, 2006 | 06:49 PM
Black Beauty's Avatar
Fantabulous idea. This is now and forever to be known as the RUDEINC LIGHT.
Where did you get it from, how much..?
Old Oct 6, 2006 | 06:54 PM
RUDEINC's Avatar
Ebay $25.00 with best offer....
http://cgi.ebay.com/ebaymotors/Under...37350306QQrdZ1
Old Oct 6, 2006 | 06:58 PM
Ronzo's Avatar
Dude, I like that.
Thanks for the tip. Definitely putting that one in the memory banks.
Old Oct 6, 2006 | 07:22 PM
Black Rose's Avatar
I like that.
Where does it plug in? Inside power socket/cigarette lighter?
Old Oct 6, 2006 | 07:27 PM
RUDEINC's Avatar
Originally Posted by Black Rose
I like that.
You directly wire it to a 12v source (like the battery). And ground.....2 wire operation...........Regards
Old Oct 6, 2006 | 07:38 PM
courthousedeb's Avatar
Cool idea. Nice job. I agree with the name for the light too.
Old Oct 6, 2006 | 07:42 PM
Novadiecast's Avatar
Great idea Mark, Didn't GM have those on C/K trucks for awhile also?
Old Oct 6, 2006 | 07:45 PM
RUDEINC's Avatar
They sure did......I remember that a friend of mine had one on his stepside...
Old Oct 6, 2006 | 07:59 PM
longhorn's Avatar
That is SWEET!
