Vanity Mirrors - Lighted
Old Jan 21, 2019 | 07:01 PM
dougcjohn's Avatar
Several threads on Lighted Vanity mirrors, but basically stating not available.
While I've got the Roof liner & all side panels out doing other projects, I was looking at the mirrors.
There is a Pink Key On Power lead going to the Ft Antenna to amplify and a few other possible sources.
Has anyone played with the Chevy Cruze vanities?
They appear to be identical, but lighted.
Their mount appears to be a 3 Screw triangle pattern like the HHR. The plastic base is slightly different shaped.
The color indicates lighted coco, the HHR indicates grey but looks light beige compared to my grey trim pieces.
Think I'll order and see what they look like...
The GM part # 95034260 is available elsewhere too... found one site that offered grey or tan.
Chevy Cruze
https://www.ebay.com/itm/95034260-Su...e/332502465282
Chevy HHR
https://www.ebay.com/itm/06-07-08-09...d/302949284283
Old Jan 21, 2019 | 11:06 PM
That pink wire is 12V when the radio is turned on not key on.
Old Jan 21, 2019 | 11:17 PM
dougcjohn's Avatar
opps... that is correct!
I was thinking source because I repurposed it for a rear combo antenna (GPS, XM, Radio) and plugged the ft location. But that was for antenna amp too.
I'll use a different source if the visor pans out.
Old Jan 22, 2019 | 05:39 AM
Lethal Tendencies's Avatar
Its pretty easy running running power down to the fuse panel. i have done it for a dash cam and power mirror with reverse camera.
crazybob
Jul 4, 2013 05:13 PM
IndianaJ.J.
Mods - Exterior
25
Mar 8, 2013 08:31 PM
catzcradle
Apr 15, 2007 04:52 PM
