Very Squeaky Noise in the back area of my panel ?
You may find that the noise comes back with silicone spray only, but it is a good test first step.
I would wipe the door latch clean and apply white lithium grease to that contact point.
Fireman G. suggestion to wipe the rubber seal clean and silicone spray was proper.
I would also use a Light coating White grease on the 2 black adjustment blocks. It will last longer.
Always clean the surfaces before applying any new lubes.
It would also be a good move to do all the side door rubber seals as well.
Lift the hood and do the latch with grease and while there put a little on all the rubber touch points.
If you know how you can also check and adjust the hood for fit and proper close.
Silverfox
Silverfox
Silverfox
Silverfox
jewels1273
Drivetrain (Excluding Engine)
13
Nov 28, 2012 06:46 PM
SSROADSTER
0
Feb 13, 2011 09:58 AM
