Very Squeaky Noise in the back area of my panel ?
Old Jun 19, 2020 | 09:23 AM
Silverfox's Avatar
You may find that the noise comes back with silicone spray only, but it is a good test first step.
I would wipe the door latch clean and apply white lithium grease to that contact point.
Fireman G. suggestion to wipe the rubber seal clean and silicone spray was proper.
I would also use a Light coating White grease on the 2 black adjustment blocks. It will last longer.
Always clean the surfaces before applying any new lubes.
It would also be a good move to do all the side door rubber seals as well.
Lift the hood and do the latch with grease and while there put a little on all the rubber touch points.
If you know how you can also check and adjust the hood for fit and proper close.
Silverfox
Old Jun 19, 2020 | 09:25 AM
Awesome! Sleeper nailed it!! And FMG got it with the silicone spray!!
Old Jun 19, 2020 | 08:07 PM
It's all good, we learn when we need to, & try & help when we believe we can.. Gotta love this forum..
Old Jun 19, 2020 | 09:02 PM
Silverfox
SF- That'll do it.. Excellent.
Squiirl421
Mar 16, 2017 08:32 PM
SandiesHank
Oct 25, 2013 06:15 PM
jewels1273
Drivetrain (Excluding Engine)
13
Nov 28, 2012 06:46 PM
an4ar2ch0y
7
Nov 4, 2011 05:48 PM
SSROADSTER
0
Feb 13, 2011 09:58 AM
