Water flooding passenger side
Ok, so these have been ruled out:
Butyl patch (not a 2006 model)
AC drain (AC hasn't been used)
Sunroof drains (no Sunroof)
Heater core (only leaks with rain)
That leaves:
Window left open
Door seals
Wiring boot in Door jamb
Leaking Windshield seal
Leaking front antenna
That leaves:
Window left open
Door seals
Thanks again man. I am being told that there is no butyl patch on a 2009 HHR. Geez that was a dumb work-around anyway. Sheesh.
So, here's where I am confused. The only water is what pools on my passenger side floor. There is no wet carpet on the sides of that floor, just the floor itself. Also, the cabin air filter on the passenger side has soaked as well. That's why I assumed it had to be a butyl patch failure. I am going to get the hose and "rain" around the door seals to see if that was the problem. Seems the seats would be wet, or the flooring between the seat and the door, which it has not been.
I'm going to pull that cowl anyway to see if the drain hole by the wheel well is packed or if there is standing water anywhere under the cowl. This car has sat for over a year as I said.
Anyway, I'll post back if I get it figured out. My thanks to everyone answering my questions.
So it could be the windshield seal, or water coming in the roof rack and flowing forward, or a window bottom seal, or plugged door drains, or drains in the front fender plugged and backfilling to fresh air intake, or a hole in the cowling (under the hood). All are good guessesThe only way to narrow it down is to start at the water and trace back. If water is running down a vertical surface, it may dry off before you see it.
