Weak sheetmetal with HHR?
Whatever it is, it is thinner (or less tempered)then the Focus, Vibe and the PT Cruiser. I tried and it takes less "effort" to buckle the metal on the hoods of those cars then my HHR. The Vibe is especially stiff. I would rather get 2 MPG less then worry about everyday door dings turning into body work.
I don't park away from other cars when i go shopping therefore I know will get my share of dings. But those dings are dents! I like the car but I wish Toyota or even Ford made it.
I don't buy the "crumple zone" argument. Stronger metal desgined right in crash tests. is far safer then thin metal designed to crumple easier.
No, crumple zones are important. Crumple zones regardless of metals thickness and strength are designed to absorb the force of impact and keep it from entering the passenger compartment. Thick metal that does not give on impact would cause much more force to be exherted on the occupants even if the car itself deformed less. So its either you life or your cars. Pick one. Me, as anal about my car as I am I'd probably rather sustain more injury to save my car. Ok maybe not. :-)
https://www.chevyhhr.net/forums/show...highlight=deer
The deer hit on that hood looks like aluminum foil ., That deer event would not have caused crumple zones to save the driver, I have seen deer tags cause much less damage then that to the eye anyway. THE PLASTIC GRILL SUFFERED LESS DAMAGE!!!! LOL
No I understand "crumple zones" They are more a function of frame design then sheet metal. In so being stronger sheet metal would absorb more of the impact.
A deer hit still would have trashed the hood (and grill and fender). Does it matter if it is a little or a lot? Either way it still would have needed replacing.
Most of what I know about metals comes from the bike world. What I can tell you is that as you get metals with a higher strength to weight ratio, you will increase the costs substantially. There are many grades of steel used in bicycle manufacturing. Almost all of them are designed to gain strength when heated (as in welding and heat treating). All of them are too expensive to be used for large panels like the ones that are used for car bodies.
Auto builders use less expensive steel alloys. With the lower cost steel, the only way to truly add strength and stiffness is to add thickness. This adds to weight (HHRs already weigh over 3000lbs) and cost as you have to use more material. The cost of steel has been steadily rising. So, I am sure that GM did the cost analisys and decided that a thinner steel was a way to cut costs without cutting content. The areas that are thin are not structural, so IMHO it has little to do with crumple zones and or crash protection. What it comes down to is this, GM wanted to hit a price point, and thinner panels and cheaper interior materials were compromises that they made in order to reach that goal.
Those who don't get dents and dings are most likely more picky about where they park and ride than I.
