What is the light/How do I turn it off
2008 2LT
Head lights on (auto mode), a ~ 1/4 dia. light is on near the controls for the sunroof. The light is distracting and I want it OFF. It must be in the manual but I can not find the answer. Thanks JMichael 2008 2LT |
That (if I understand your post correctly) is the LED that is aimed at the window switches for nite visibility.
I like it myself.. |
And you cannot turn it off. You can however, take the cover off and disconnect it, or put in a little switch on that cover, if it bothers you that much.
its the GM mood light...grab it with a pair of needle nose pliers and break it..if it bothers you...But you can unplug it.....
Tape?
Originally Posted by wuds
(Post 647745)
Tape?
Originally Posted by 843de
(Post 647748)
You should know that you only use tape to cover the "Check Engine Light" when it won't go off.:wink:
:roflol:
(Post 647748)
good for the seatbelt light, but then mine goes out on it's own after 5 minutes or so.
