What are the lights on heater control knobs?
Originally Posted by nfboy
Page 3-21
Rear Window Defogger
The rear window defogger uses a warming grid to
remove fog from the rear window.
The rear window defogger will only work when the
ignition is in RUN.
<(Rear): Press the button to turn the rear window
defogger on or off. Be sure to clear as much snow from
the rear window as possible. An indicator light below
the symbol will come on to let you know that the
rear window defogger is activated.
The rear window defogger will turn off approximately
15 minutes after the button is pressed. If turned on
again, the defogger will only run for approximately
seven minutes before turning off. If turned on again, the
defogger will only run for approximately seven minutes
before turning off. If vehicle speed is greater than 50 mph
(80 km/h) and the rear defogger is active, it will remain on
as long as the speed is greater than 50 mph (80 km/h).
The defogger can also be turned off by pressing the
button again or by turning off the engine.
Notice: Do not use anything sharp on the inside of
the rear window. If you do, you could cut or damage
the warming grid, and the repairs would not be
covered by your warranty. Do not attach a temporary
vehicle license, tape, a decal or anything similar to
the defogger grid.
3-21
ignition is in RUN.
the defogger grid.
3-21
Theres a sticky post where you can download a owners manual, seems like if it`s on the computer, people would read it... ( oops, hope I`m not in trouble)
I went on a search to let you know where to find it, not successful, maybe Courthouse Deb will jump in here... She`s pretty good at finding stuff. I`m not ( except trouble ).
I am glad someone else started this. I also have some questions about the air. I live here in Houston and have the air on all the time. I noticed the button (light)on the temp control knob. There does not seem to be a difference if the light is on or off. I know it says it is to turn the air off and on. Oh well car works great 32 mpg @ 80 miles per hour who can complain?
Originally Posted by Harpozep
Yeah, this car keeps surprising me. I read here about the intermittent wipers going into full mode when going over 45 MPH. Sure enough, it is true. It is likely in the owners manual, but I must have glossed over it.
Here is the Sticky Thread link for the Owners ManualI hope this helps!
Originally Posted by James06
Mine doesn't do this. I'm glad it doesn't, since I'm almost always over 45 mph, but now I wonder if I should get it checked.
