What is the stupidest design error?
Old Jun 11, 2011 | 04:29 AM
  #31
SHADOW(IN)'s Avatar
Originally Posted by 08bowtie
having to change 2 tires when i have a flat because the donut tire wont work on the front....really???? comon man.....
WOW !! did not know that ....
On the lower rocker ground fx. at the front door area ice builds up . (
Old Jun 12, 2011 | 07:15 AM
  #32
stanvalp's Avatar
the power window buttons should have been at the top of the waterfall, where the dimmer is. the extreme wind buffeting with the rear windows down is the worst. the pressure spikes hurt our ears.
Old Jun 12, 2011 | 08:33 AM
  #33
sideout94's Avatar
I think it is a toss up between replacing the headlamps and the window switches. I have owned my '07 for over a year now and still reach to the door to open the windows. Wont give mine up for anything though! love the looks i get in it!
Old Jun 12, 2011 | 07:04 PM
  #34
MacroAlan's Avatar
My friends get in and lock the doors trying to find the power window controls.
Old Jun 12, 2011 | 07:37 PM
  #35
bassbase's Avatar
I believe I would vote for the top 3 being the headlight bulb replacement, the lack of a keyhole to manually open the hatch and did not know about the spare not fitting on the front (now that is lobotomy stupid)
Old Jun 12, 2011 | 07:39 PM
  #36
87silver's Avatar
Originally Posted by nacademus
Battery in the rear, no mechanical key hole to pop the hatch FROM OUTSIDE! I know there is a little access louver you can pop off, but damn.
Whole heartedly agree about no manual key latch for the rear hatch, especially if the battery goes dead. This is a monumental blooper and should go down in automotive blunder history with the Edsel.
As far as the battery location itself, being someone who has been dealing with VRLAs and flooded cells for years, this location will surely promote the longevity, because it is not subject to the rigors of high under hood temps and rapid temp changes. I wish all my vehicles had the starting batteries away from the heat of the engine compartment.
Old Jun 12, 2011 | 07:42 PM
  #37
JavaMann's Avatar
Is the 'spare not fitting the front' limited to the brembo-equipped SS's, or is applicable to the LS and LT's also?
Old Jun 12, 2011 | 08:08 PM
  #38
Brembo....
Old Jun 12, 2011 | 08:32 PM
  #39
LewiSS's Avatar
This is an SS-only issue, but the fact that the GM Stage 1 kit is so unreliable, takes a Flight-qualified soldering tech to install, all because GM was too cheap to install connectors to make it plug-and-play. What a total rip-off!
Old Jun 12, 2011 | 10:50 PM
  #40
X 2 on both points !!!!
