Wheel Speed Sensor
Old Oct 21, 2023 | 04:13 PM
What usually happens is that somebody removes the fuse box then tightens the bolts "until I was afraid they would strip"; that is not tight enough to get all of the blades seated into their slots. That is always the cheapest and quickest thing to try first along with the battery and power steering connections on the side of the fuse box.
Old Oct 21, 2023 | 05:40 PM
Mjdevee's Avatar
Awesome!!! Thank you for explaining that that to me. I wasn’t quite sure what exactly people were talking about. Lol. Sorry. We got a newbie here. 😁 quickly learning though.
Old Oct 21, 2023 | 09:46 PM
greg8453's Avatar
The ABS module will not send the engine into safe mode (limp). The tranny code is what you need. That's going to be a PO7xx code.
Old Oct 22, 2023 | 08:18 AM
VVT and timing codes can cause Traction and ABS along with hard shifting in an attempt to tell the driver to pay attention to the CEL. What some call "limp mode"; too many mechanics think it is.
Limp home mode comes from overheating; the computer starts firing the spark plugs and injectors alternating cylinders in an attempt to get the driver to park the car before the engine and catalytic converter melt down. Far more serious than just hard shifting. I have experienced it.
Old Oct 23, 2023 | 03:54 PM
Mjdevee's Avatar
So I got my car back today. It was the Transmission Speed Control sensor or something like that. Either way, no lights are on. No “Limp” and the door locks aren’t freaking out anymore.
Old Oct 23, 2023 | 05:51 PM
Mjdevee's Avatar
Okay…..So I went for a long drive. Took it on the expressway. I’m hitting almost 3500 rpms before it shifts in to another gear. Also, didn’t shift in to high gear I don’t think. Between 70-80mph I’m runnings about 4000 rpms. It’s also slow from a stop and doesn’t shift out of 1st until 3-3500 rpms. They replaced the transmission speed sensor is what I was told today. He could have said the wrong thing though. I’m not a mechanic by any means. Does it need to be “recalibrated”? Or maybe did I slip in to the “I” gear by accident? The shift solenoids were replaced not that long ago from what I’m being told.
Old Oct 26, 2023 | 11:19 AM
PulpFriction's Avatar
Still no codes?
Old Oct 26, 2023 | 03:05 PM
greg8453's Avatar
Did they flash the TCM?
DangerBoy
May 31, 2020 06:35 PM
Bob Hayman
Dec 26, 2014 02:51 PM
Blue Beast (aka Boydie)
Maintenance and Upkeep
11
Nov 13, 2013 10:58 PM
gif1402
Oct 6, 2013 02:15 PM
iuvenesco
Feb 11, 2009 11:55 PM
