Chevy HHR Network
-   General HHR (https://www.chevyhhr.net/forums/general-hhr-4/)
-   -   Where is the Evap Purge Valve on a chevy hhr 2007 (https://www.chevyhhr.net/forums/general-hhr-4/where-evap-purge-valve-chevy-hhr-2007-a-54103/)
tomdel50 Jun 24, 2015 02:53 PM
chevy hhr 2007 can not find the evap canister purge vale under the hood
i have a diagram but still can not find it. are there any pics ?
donbrew Jun 24, 2015 03:00 PM
It's the black box attached to the driver side of the head under the air filter. 2 hard black hoses and 1 electrical connector. One of the hoses connects to the intake manifold the other disappears under the car near the firewall.
Oldblue Jun 24, 2015 04:09 PM
Welcome to the site, why the need to find the valve? A code?
tomdel50 Jun 24, 2015 05:49 PM
Oldblue- getting a PO455 i replaced the gas cap, and the valve in the rear need to try the one by the engine. dealer want around $200 just to check it out.
whopper Jun 24, 2015 06:13 PM
P0455, not pO455 - important difference if you try and search for it here or via Google.
donbrew Jun 24, 2015 06:47 PM
Then that will not be the problem.
OBD-II Trouble Code: P0455 Evaporative Emission Control System Leak Detected (no purge flow or large leak)
Oldblue Jun 25, 2015 01:12 PM
Read the post that Don provided, hope it helps you resolve your issue
Kersh Jun 25, 2015 02:34 PM
As far as location, I think you're referencing the valve at the canister, back by the fuel tank.
2007 Chevrolet HHR VAPOR CANISTER & RELATED PARTS
donbrew Jun 26, 2015 07:29 AM
Kersh you are falling for a GM nomenclature joke.
Canister PURGE valve: under hood. Canister VENT valve: near gas tank.
tomdel50 Jun 26, 2015 11:59 AM
was talking the one under the hood i have located it
