Dome lights
Old 11-01-2013, 08:18 AM
F-16C's Avatar
Dome lights
My question is can you turn off the dome lights manually ?I looked through the owner manual and can not fine it.
F-16C is offline
Old 11-01-2013, 08:44 AM
Pretty sure that got discussed a couple years ago. If I remember correctly, the answer was No.
They will "time out" on their own if you leave a door open with the engine off. Something like 10 mins. or so, then the battery saver mode kicks in.
firemangeorge is offline
Old 11-01-2013, 09:41 AM
Technical Moderator
Which do you mean? The one that comes on when you open the door or the map lights? Map lights just push on the lens (if you leave them on, they will time out).
donbrew is offline
Old 11-01-2013, 12:10 PM
F-16C's Avatar
Thats what I thought. Reason for my question is, I shut the door last night and the dome lights did not go off. After going back into the dark garage 30 min later I found them on. After shutting the drivers door a few times it went out. I can not believe GM did not put a OFF override switch for the dome lights.
F-16C is offline
Old 11-01-2013, 04:33 PM
Technical Moderator
Depends on the year & model, there are at least 3 variants of "Dome Light" that I have heard of.
donbrew is offline
bubbacharles
Mods - Interior
28
08-28-2013 11:19 PM
shaunmcg
08-13-2013 06:27 PM
Black Rose
10-23-2012 08:30 PM
tntwolt
Mods - Interior
11-30-2011 08:24 PM
HHRMom_0791
10-17-2011 10:03 AM
Quick Reply: Dome lights
