windshield washer tank
my storage tank for the windshield washer fluid is leaking . and for the life of me I can't seem to find the leak. How does this animal come out.
Thought I would fill with water when out
or has anyone else had this happen
or........... thanks
3 nuts to remove. (1 on bottom is hard to see). I think they're 10mm.
Disconnect the electrical plug and washer fluid line.
Lift it off of the 3 bare studs and remove.
Fwiw. Other folks have posted up about theirs leaking around the washer pump grommet.
Most likely the internal pump seal has failed. The pump is a friction fit; just pull the top out and the bottom sticks in the hole, with a grommet. No need to remove the tank.
Windshield Washer Pump ACDelco GM Original Equipment fits 06-11 Chevrolet HHR | eBay
REDFLYR
06-20-2008 11:00 PM
