windshield washer tank
my storage tank for the windshield washer fluid is leaking . and for the life of me I can't seem to find the leak. How does this animal come out.
Thought I would fill with water when out or has anyone else had this happen or........... thanks |
3 nuts to remove. (1 on bottom is hard to see). I think they're 10mm.
Disconnect the electrical plug and washer fluid line. Lift it off of the 3 bare studs and remove. Fwiw. Other folks have posted up about theirs leaking around the washer pump grommet. |
thanks firemangeorge, i'll look into that and post a reply
Most likely the internal pump seal has failed. The pump is a friction fit; just pull the top out and the bottom sticks in the hole, with a grommet. No need to remove the tank.
https://i.ebayimg.com/thumbs/images/...8~n/s-l225.jpgWindshield Washer Pump ACDelco GM Original Equipment fits 06-11 Chevrolet HHR | eBay |
Mine was the grommet, cost about a buck. Fixed
