GM Recall Campaigns For Information & Discussion of General Motors Recalls
Key Stuck In Ignition Warrenty Extention - Not a recall #14632
Old 06-17-2015, 06:34 PM
  #71
Snoopy's Avatar
greenied.....
I'm glad the GM "system" stepped up and provided you a remedy. There is a wealth of information on this forum from very knowledgeable people and this outcome proves it.
Snoopy is offline
Old 06-28-2015, 02:04 AM
  #72
Greenied1's Avatar
Originally Posted by Snoopy
greenied.....
That's right! I know I never would have been able to get this completed at no charge without the help of everyone here. I'm well and truly thankful!
Greenied1 is offline
Old 01-17-2019, 09:59 PM
  #73
Some do and some don't. But in my opinion and in this instance, if you are experiencing EVERYTHING THAT I OUTLINED, it is a separate issue and should be repaired without charge.
This special Customer Satisfaction repair that I am speaking of should be attached to your VIN and the dealer should be able to see it on the GM vehicle information system......and NO CHARGE.
Gotta love this forum.
sleeper is offline
Old 01-18-2019, 09:33 AM
  #74
Yes, now get your shifter and ignition work done.
Youll be glad you did!
Oldblue is offline
Old 01-18-2019, 08:50 PM
  #75
That's the plan....Only thing is, it hasn't happened since posting. But likely will when I least expect it.
Dealer said it was illegal to fix something else on my ride while I have a TPMS light on from a dead sensor battery, said they must fix that first. No way would I pay $90. per sensor there + labor.
sleeper is offline
Old 01-19-2019, 08:51 AM
  #76
Then buy a set off RockAuto and have your local shop install them!
https://www.rockauto.com/en/catalog/...)+sensor,12036
don’t forget the discount code!
Oldblue is offline
Old 01-19-2019, 01:36 PM
  #77
THat's the plan, but not till spring when I put on new tires w/new sensors at same time.
sleeper is offline
Old 01-19-2019, 02:09 PM
  #78
Ok, but park the panel , as it is in an unsafe condition to operate, due to the recall not performed yet.
Oldblue is offline
Old 01-19-2019, 08:03 PM
  #79
Blue- Thank You for your concern. It's parked right now.
But the recall began in 2013, I believe.
sleeper is offline
Old 01-20-2019, 08:39 AM
  #80
So, you’ve ignored the recall letter since then?
Oldblue is offline
Quick Reply: Key Stuck In Ignition Warrenty Extention - Not a recall #14632
