09 SS Turbo out
09 SS Turbo out
So it appears my Turbo has gone out... Stepping on the gas bogs down the engine instead of turbocharging it, and parking the car doesn't result in that little metallic click. Not seeing any codes either. Could use some ideas on how to troubleshoot
Wow, that could be a lot of things, don't even know where to start.
Maybe look into the "no click" situation first. Perhaps whatever is causing that is making the computer say "Houston, we have a problem, must protect the system, no turbo for you!"
What metallic click are you talking about?
Low fuel pressure could be a possible cause also.
I would hope low fuel pressure would show up on the ecm...
I've never noticed a click. Right before you park or shut off engine, the engine is at idle, and there is no boost to depressurize. Are you sure the click is not from the shifter moving into 'park'? Of course, now you can't check because it is not clicking anymore...
Simple things, like check your oil and coolant levels, the turbo needs both.
If anyone is interested, here's a diagnostic log
Mode $06 report generated by Torque for Android
Vehicle VIN: 3GNCA73X89S621057
Vehicle Manufacturer: Chevrolet
Vehicle Calibration ID: 12629314
12633787
12629330
12629332
Test report:
MID:$01 TID:$83
- O2 Bank 1 Sensor 1
Max: 1.99882 Min: 0.29988
Test result value: 1.00723
PASS
MID:$01 TID:$84
Max: 0.06997 Min: -0.06997
Test result value: -0.00149
PASS
MID:$02 TID:$05
Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2
Max: 400ms Min: 0ms
Test result value: 10ms
PASS
MID:$02 TID:$07
Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 0.44969V Min: 0V
Test result value: 0V
PASS
MID:$02 TID:$08
Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2
Max: 1.14778V Min: 0.44969V
Test result value: 0.89938V
PASS
MID:$02 TID:$81
Max: 0.64026V Min: 0V
Test result value: 0.6305V
PASS
MID:$02 TID:$82
Max: 1.14778V Min: 0.64026V
Test result value: 0.65002V
PASS
MID:$21 TID:$84
- Catalyst Monitor Bank 1
Max: 1.99882 Min: 0.20301
Test result value: 0.92915
PASS
MID:$39 TID:$80
Test incomplete or dependant test failed
MID:$3c TID:$80
- EVAP Monitor (0.040")
MID:$3d TID:$88
- EVAP Monitor (0.020")
MID:$3d TID:$8c
MID:$41 TID:$85
- O2 Heater Monitor Bank 1 - Sensor 1
Max: 1,302.80005°C Min: 805°C
Test result value: 820.20001°C
PASS
MID:$42 TID:$81
- O2 Heater Monitor Bank 1 - Sensor 2
Max: 900Ohm Min: 0Ohm
Test result value: 124Ohm
PASS
MID:$81 TID:$80
- Fuel System Monitor Bank 1
Max: 6.04% Min: -6%
Test result value: 0.6%
PASS
MID:$81 TID:$82
Max: 1.31925 Min: 0.77958
Test result value: 1.11072
PASS
MID:$a2 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data
Max: 65,535Count Min: 0Count
Test result value: 0Count
PASS
MID:$a2 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data
PASS
MID:$a3 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data
PASS
MID:$a3 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data
PASS
MID:$a4 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data
PASS
MID:$a4 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data
PASS
MID:$a5 TID:$0b
EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data
PASS
MID:$a5 TID:$0c
Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data
PASS
End of report.
12633787
12629330
12629332
Test report:
MID:$01 TID:$83
PASS
MID:$01 TID:$84
PASS
MID:$02 TID:$05
Max: 400ms Min: 0ms
PASS
MID:$02 TID:$07
PASS
MID:$02 TID:$08
PASS
MID:$02 TID:$81
PASS
MID:$02 TID:$82
PASS
MID:$21 TID:$84
PASS
MID:$39 TID:$80
MID:$3c TID:$80
MID:$3d TID:$88
MID:$3d TID:$8c
MID:$41 TID:$85
PASS
MID:$42 TID:$81
PASS
MID:$81 TID:$80
Max: 6.04% Min: -6%
PASS
MID:$81 TID:$82
PASS
MID:$a2 TID:$0b
PASS
MID:$a2 TID:$0c
PASS
MID:$a3 TID:$0b
PASS
MID:$a3 TID:$0c
PASS
MID:$a4 TID:$0b
PASS
MID:$a4 TID:$0c
PASS
MID:$a5 TID:$0b
PASS
MID:$a5 TID:$0c
PASS
End of report.
If the waste gate valve is hung open or missing, I can see you having a low boost condition.
FYI.
I hear that click also. Sounds more like a light "clunk" sound. About 20 seconds after shutdown like the OP stated.
The closest thing that I can compare it to. You know that little safety ball in a shop vac that shuts off the suction when the shop vac tips over ? When you shut the vac off and the safety ball slides back to position, the clunk sound it makes is comparable to the sound my SS makes.
I think it was our member Dr. Loch that explained one time what that noise is. Maybe he'll read this and post up some info.
I believe it's something to do with the throttle plate.
Found a couple threads
https://www.chevyhhr.net/forums/hhr-...hutdown-17977/
https://www.chevyhhr.net/forums/hhr-...-parked-14711/
Just tried it on my SS. Just like in post #13 of the second link, it did really sound like the throttle body.
So if your throttle body is not working properly, that could certainly cause the issues you're having.
