2007 hhr ls brake issues
Old 06-01-2018, 11:59 PM
Briguy64's Avatar
replaced front wheel brake capiers and pads. new rear wheel cylinders, and master cylinder. bleed all the lines. brake pedal is hard until the car is started. then brake pedal goes to the floor and there is no brakes. cylinders and calibers are moving but still no brakes. at a lost what to do/check next.
Briguy64 is offline
Old 06-02-2018, 01:00 AM
Welcome.
Did you bench-bleed the master cylinder before installing it?
ie: https://www.thoughtco.com/bench-blee...ylinder-281381
whopper is offline
Old 06-02-2018, 09:50 AM
Technical Moderator
Booster?
donbrew is offline
Old 06-02-2018, 11:51 AM
Was the car having this problem before this work was done?
RJ_RS_SS_350 is offline
Old 06-02-2018, 04:32 PM
Welcome to the site
Did you bleed the brakes in order?
RR,LR,RF,LF
Did you bleed the distribution block?
Oldblue is online now
Arkygirl
01-29-2023 09:48 PM
Michael Benedict
08-20-2016 11:07 AM
LuckyLadySD
06-12-2014 02:09 AM
Old Ray
03-29-2008 02:29 PM
Quick Reply: 2007 hhr ls brake issues
