09 SS Turbo out
So it appears my Turbo has gone out... Stepping on the gas bogs down the engine instead of turbocharging it, and parking the car doesn't result in that little metallic click. Not seeing any codes either. Could use some ideas on how to troubleshoot
Wow, that could be a lot of things, don't even know where to start.
Maybe look into the "no click" situation first. Perhaps whatever is causing that is making the computer say "Houston, we have a problem, must protect the system, no turbo for you!" |
Originally Posted by ducky69247
(Post 839801)
What metallic click are you talking about? Low fuel pressure could be a possible cause also. |
Originally Posted by Cat Man HHR
(Post 839815)
What are you getting for boost? Max is 14/15 psi stock.
What metallic click are you talking about? Low fuel pressure could be a possible cause also. I would hope low fuel pressure would show up on the ecm... |
I've never noticed a click. Right before you park or shut off engine, the engine is at idle, and there is no boost to depressurize. Are you sure the click is not from the shifter moving into 'park'? Of course, now you can't check because it is not clicking anymore...
Simple things, like check your oil and coolant levels, the turbo needs both. |
(Post 839846)
Simple things, like check your oil and coolant levels, the turbo needs both. If anyone is interested, here's a diagnostic log Mode $06 report generated by Torque for Android ================================================ Vehicle VIN: 3GNCA73X89S621057 Vehicle Manufacturer: Chevrolet Vehicle Calibration ID: 12629314 12633787 12629330 12629332 Test report: ------------------ MID:$01 TID:$83 - O2 Bank 1 Sensor 1 Max: 1.99882 Min: 0.29988 Test result value: 1.00723 PASS ---- MID:$01 TID:$84 - O2 Bank 1 Sensor 1 Max: 0.06997 Min: -0.06997 Test result value: -0.00149 PASS ---- MID:$02 TID:$05 Rich to Lean sensor switch time(calculated) - O2 Bank 1 Sensor 2 Max: 400ms Min: 0ms Test result value: 10ms PASS ---- MID:$02 TID:$07 Minimum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2 Max: 0.44969V Min: 0V Test result value: 0V PASS ---- MID:$02 TID:$08 Maximum sensor Voltage for test cycle(calculated) - O2 Bank 1 Sensor 2 Max: 1.14778V Min: 0.44969V Test result value: 0.89938V PASS ---- MID:$02 TID:$81 - O2 Bank 1 Sensor 2 Max: 0.64026V Min: 0V Test result value: 0.6305V PASS ---- MID:$02 TID:$82 - O2 Bank 1 Sensor 2 Max: 1.14778V Min: 0.64026V Test result value: 0.65002V PASS ---- MID:$21 TID:$84 - Catalyst Monitor Bank 1 Max: 1.99882 Min: 0.20301 Test result value: 0.92915 PASS ---- MID:$39 TID:$80 - Test incomplete or dependant test failed -- MID:$3c TID:$80 - EVAP Monitor (0.040") Test incomplete or dependant test failed -- MID:$3d TID:$88 - EVAP Monitor (0.020") Test incomplete or dependant test failed -- MID:$3d TID:$8c - EVAP Monitor (0.020") Test incomplete or dependant test failed -- MID:$41 TID:$85 - O2 Heater Monitor Bank 1 - Sensor 1 Max: 1,302.80005°C Min: 805°C Test result value: 820.20001°C PASS ---- MID:$42 TID:$81 - O2 Heater Monitor Bank 1 - Sensor 2 Max: 900Ohm Min: 0Ohm Test result value: 124Ohm PASS ---- MID:$81 TID:$80 - Fuel System Monitor Bank 1 Max: 6.04% Min: -6% Test result value: 0.6% PASS ---- MID:$81 TID:$82 - Fuel System Monitor Bank 1 Max: 1.31925 Min: 0.77958 Test result value: 1.11072 PASS ---- MID:$a2 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 1 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a2 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 1 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a3 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 2 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a3 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 2 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a4 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 3 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a4 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 3 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a5 TID:$0b EWMA Misfire counts (average) for last 10 drive cycles - Misfire Cylinder 4 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- MID:$a5 TID:$0c Misfire counts for last/current driving cycles(calculated) - Misfire Cylinder 4 Data Max: 65,535Count Min: 0Count Test result value: 0Count PASS ---- End of report. |
When did you clear codes and why?
I can tell because the EVAP tests are incomplete. |
(Post 839847)
It keeps pressure by default from what I have figured out. So that it's always ready to go. And when it doesn't need it, it releases it.
If the waste gate valve is hung open or missing, I can see you having a low boost condition. |
FYI.
I hear that click also. Sounds more like a light "clunk" sound. About 20 seconds after shutdown like the OP stated. The closest thing that I can compare it to. You know that little safety ball in a shop vac that shuts off the suction when the shop vac tips over ? When you shut the vac off and the safety ball slides back to position, the clunk sound it makes is comparable to the sound my SS makes. I think it was our member Dr. Loch that explained one time what that noise is. Maybe he'll read this and post up some info. I believe it's something to do with the throttle plate. |
Found a couple threads
https://www.chevyhhr.net/forums/hhr-...hutdown-17977/ https://www.chevyhhr.net/forums/hhr-...-parked-14711/ Just tried it on my SS. Just like in post #13 of the second link, it did really sound like the throttle body. So if your throttle body is not working properly, that could certainly cause the issues you're having. |
