09 SS w Performance Pkg - winter tires
Purchased 09 HHR with performance package (limited slip diff + Brembo brakes). Great little beastie, but maybe performance package was a mistake. Wanted the limited slip for winter, but no aftermarket wheels that fit huge front Brembo's, so can't put on winter wheel package. (Dealer quote for second set of stock rims - $2700!) Surfed sister forum (Cobalt SS) since they have had Brembo's longer. Same problem and much frustration. Tire Rack and Discount Tire both say they need to get vehicle in to take measurements to make recommendation. Anyone out there with same vehicle live close enough to drive over to either location and let them measure?
Oh, and if you want, I'll trade the brakes on my 08ss for your brembos.
Welcome to the site! I'll bet these will clear...
https://www.chevyhhr.net/forums/deleted-threads-41/wtb-2-17-wheels-17178/
Wheels: Wheel 1 Wheel 2
Wheel size 18x7.5 ET 42 17x7 ET 42
BackSpace 150 mm (5.9'') 143 mm (5.6'')
7 mm (0.3'') shorter.
Rim Lip 7 mm (0.3'') wider
Tires: Tire 1 Tire 2
Tire size 215/45-18 215/50-17
Section width 215 mm (8.5'') 215 mm (8.5'')
Sidewall 97 mm (3.8'') 108 mm (4.3'')
Tire diameter 651 mm (25.6'') 648 mm (25.5'')
3 mm (0.5%) shorter.
Rim sizes 18x6 to 18x8 17x6 to 17x8
Circumference 2044 mm (80.5'') 2035 mm (80.1'')
Revs per mile 787.3 790.9
Speedometer Assuming that this is OEM tire and speedometer readings are correct When speedometer reads 60mph (96.6km/h) actual speed will be 59.7mph (96.1km/h): 0.5% slower.
Clearance: Package 1 Package 2
Suspension Assuming that this is OEM
wheel/tire and there is not any problems
with clearance on both sides The same.
Fenders The same.
Wheelwells The same.
Fenders The same.
You jest of course, but interestingly in frustration I did ask dealer about swapping for base SS brakes. Don't remember the quote exactly but it was huge. Not just the calipers, but the disk and hub would need to be changed. Also voids the warranty. In any case the Brembos seem to be good for bragging rights, and you can't have brakes that are too good, so hope to solve the rim problem instead.
I'm new to this forum, so thought "quick reply" was on a message basis. Last reply was to AaronSS. This one to others. Thanks to all.
To JeffS396 - thanks; I have an appointment at dealer to try one of these. (They have upped the price to $150 retail though and want a liability waiver to sell for different vehicle than intended)
To Canuck - yes would like more tire, less rim for winter driving. We get lots of frost heaving and potholes here. Maybe more than even your location given large swings in winter temperature.
To CokeyBill - thanks for all of the info and the great web site.
With no disrespect to you, and this is just my
, but I sure wouldn't worry about what the dealer thinks is appropriate wheels for my HHR! It's pretty much black & white...they either clear the calipers or they don't! Rear fitment will NOT be an issue for sure, fronts can't say for sure...mine has standard brakes...plenty of clearance! Please don't pay that for these rims, they just sold you a $22K+ vehicle & want you to pay full retail for these???
Here's the latest from GMPartsDirect.com...
GM PART # 9597624
CATEGORY: Wheels
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $150.73
OUR PRICE: $92.49[/QUOTE]
Also, I have 225/50/17 Michelins on mine, actually the same tire that comes on your SS, only in 17" diameter. The diameter of this size is exactly the same as your 18" combo, but have the added benefit of a taller sidewall for your winter driving use.
If you visit this site:
http://www.car-part.com/
you can find one of these rims at a local salvage yard, just search under 2006 pontiac G6 with 17" steel rims. Go there & physically try one on the front, then you'll know for sure before you order. The tire rack is always a good source for closeout rims, you could always go aftermarket alloy 18" for probably less than $150/wheel! Good luck!
, but I sure wouldn't worry about what the dealer thinks is appropriate wheels for my HHR! It's pretty much black & white...they either clear the calipers or they don't! Rear fitment will NOT be an issue for sure, fronts can't say for sure...mine has standard brakes...plenty of clearance! Please don't pay that for these rims, they just sold you a $22K+ vehicle & want you to pay full retail for these??? Here's the latest from GMPartsDirect.com...
GM PART # 9597624
CATEGORY: Wheels
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $150.73
