7163 turbo and auto trans ?
Anyone ever run this turbo on a auto at the drag strip ?
I had zzp installed and tuned my 6758 on my ss auto. Even with that turbo I am only tuned to 23psi. With running more boosts I will be risking destroying my tyranny. At least that what zzp tuner told me.
After just a quick search it appears there is some fabrication involved and then tuning, and that many mm larger, might cause a lot more spool up time I would consider the K04 if your SS is a DD. |
I already have the 7163 in.. was just curious if anyone took it to the track being in a auto is all.
Ah, I see, well it’s test and tune time then, I don’t recall anyone with that setup. |
Originally Posted by Ohiocruiser
(Post 849517)
Originally Posted by Oldblue
(Post 849523)
Unfortunately we don't have a lot of options with auto transmission. Reducing shift time with tune and installing extra trans cooler, that about all I can think of. How much are you making with that turbo on 25 psi?!! Shold be around 380-400 whp
Yea not much you can do. Tune it .. trans cooler .. good fresh fluid . And I don't know never dynod it. Yet ! But I have more mods also cams and all bolt ons also.
(Post 849518)
After just a quick search it appears there is some fabrication involved and then tuning, and that many mm larger, might cause a lot more spool up time I would consider the K04 if your SS is a DD. you would consider the stock turbo? or did you mean K04R? |
