Adding LSD to non-LSD car
Old 10-26-2017, 09:29 AM
fonque's Avatar
I am looking for some advice on which would be the better way to go.
I have been working on my HHR build for some time. I have the suspension and brakes done, and solid motor mounts. Traction in a straight line is adequate with good tires. But I am still having issues in turns.
Would it be better to have a quaife installed or just pick up a used G85 transmission?
I know the quaife installed by itself would be significantly more expensive, but I need to upgrade my clutch, so I figured I would have it done at the same time to cut down on labor.
I would like to get all of this sorted before I start adding anymore power.
Any help is appreciated!
fonque is offline
Old 10-26-2017, 10:23 AM
Technical Moderator
People that can help will want to know: is this a daily driver or a race car, what kind of competition, what "issues in turns"?
I don't know much about it, but wouldn't LSD make for more problems in turns? I thought LSD is for straight line acceleration.
donbrew is offline
Old 01-09-2018, 07:19 PM
ThoR294's Avatar
you're thinking of an actual locker, where it locks both wheels to turn at the same speed no matter what. LSD is a "Limited Slip Differential", which puts power to boths wheels and allows the wheels to "slip" when cornering, so you don't get wheel hop.
ThoR294 is offline
Old 01-09-2018, 09:25 PM
prod's Avatar
https://www.carthrottle.com/post/eng...table-for-you/
prod is offline
Old 07-21-2018, 06:40 AM
OshawaHHRss's Avatar
Team green LSD insert with upgraded springs
4.17 new style F23 (from 2007 base model hhr) w. LSD
I put a team green LSD insert in a 4.17 F23 for my SS. You can use them in the automatics too actually
OshawaHHRss is offline
Old 07-21-2018, 07:37 AM
Cat Man HHR's Avatar
That is not a locker but what's called a spool. A locker will unlock when going thru a turn. The ones I knew about did make a clunk or loud click when the unit re-engaged when going straight from out of a turn.
Cat Man HHR is offline
Old 07-21-2018, 07:40 AM
Is it possible to post pictures of the install? Would like LSD in my automatic.
Old 07-21-2018, 07:51 AM
I took it to a tranny shop to do it or I would have taken some
Old 07-21-2018, 12:18 PM
So how do you know the parts you showed will work in an automatic?
Old 07-23-2018, 05:55 PM
Blue_SS's Avatar
I am going to guess, but you might need to row your own gears for LSD. I don't personally know of LSD applications in FWD automatics. I hope to be proven wrong...
Blue_SS is offline
Quick Reply: Adding LSD to non-LSD car
