Air Filter
Old Dec 29, 2008 | 09:58 PM
Owebo's Avatar
Air Filter
I have yet to find a part number for a regular replacement paper element air filter, does anyone know if one exists and where to get it from?
Old Dec 30, 2008 | 05:49 AM
hyperv6's Avatar
Might look in the owners manual as they usally list often replaced filter numbers in them.
Old Dec 30, 2008 | 07:34 AM
Old Lar's Avatar
Go to the dealer and get one. I picked up one at Auto Zone, just look through their cross reference book for part #s.
Old Dec 30, 2008 | 09:50 AM
jerSSey HHR's Avatar
How difficult is it to replace the air filter? Simple access to the airbox?
Old Dec 30, 2008 | 10:57 AM
08blackHHRSS's Avatar
FYI: If your auto parts say they can order you one, right now i don't think thats true. I had 2 places order one(a chain store and a ol fashioned auto parts, going by what their Fram info said it was) and both of them handed me a flat, retangular box, NOT a SS filter
Between the real auto parts guy and mine checking into this, and cross referencing we found out the (hopefully) a Wix filter might be the right one (the specs given when he called their tech line came back with one that matches my measurements ) Don't have the part # in front of me, but will post it here ASAP when i find where i left it
Also, Amsoil claims they have one too, but i can't confirm that (might be the rectangle /flat filter thing all over again.)
I realize it's kinda early for aftermarket filters to be on shelves, but with my kinda driving (prob 40K+ a yr) i tend to go thru stuff like this a lil sooner than most.And that sometimes runs into problems like this, not finding parts available this soon.
Old Dec 30, 2008 | 11:02 AM
On a SS, it's easier (i've heard) than the non SS (one auto parts gal has a non SS, and she said it was a decent amount of work to R+R a air filter in hers. I told her i already took mine out and lightly blew it out w/ air just to see what the filter might have already trapped,and it was very easy)
A few Torx screws and the cover comes off, and the filter is right there, pretty much pull it off the neck that holds it, and reverse to install.Have not figured out what (or if i should bother) i could use in the cover screwholes to allows easy removal in the future,just want to have the metal screw/plastic body relationship to last a long time b4 it might open those holes up w/ repeated remove/install.Right now i used a lil bit of silicone grease just so the screw does not "lock up" in the hole later on.
Old Dec 30, 2008 | 02:02 PM
Thanks for the info. I might check mine at around 10K miles.
RBodeman
2.0L Performance Tech
10
Oct 9, 2012 09:49 PM
55bowtie
Maintenance and Upkeep
Oct 29, 2011 09:08 PM
dvalin
Mar 25, 2008 02:47 PM
