Air Intake issues
Old Jun 17, 2014 | 10:55 AM
wagoneer's Avatar
Air Intake issues
Do I went the mountains last week and gps took me down a dirty road. On the way home my check engine light came on and my car was having a hard time getting up an incline. I took it by a partys store and checked the codes. All were related to air intake, O2 sensor, running to rich ect.
I went home and cleaned my K&N filter but the next day the check engine light came on. It's running rough and the power is reduced. Anyone know what I should be looking at?
Old Jun 17, 2014 | 11:15 AM
07azhhr's Avatar
Have you checked your intake piping for leaks? Perhaps the roughness of the road (if it was) shook some piping loose.
Old Jun 17, 2014 | 11:29 AM
Dirty MAF most likely. Always post the code numbers, otherwise you are giving garbage in for garbage out.
Old Jun 17, 2014 | 11:40 AM
wagoneer's Avatar
Here are the codes.. p2178 p0101 p0234 p0299 p2227 p2199
Old Jun 17, 2014 | 12:47 PM
Every one of those points to you over oiled your K&N. Causing a mucked up MAF.
Your next step should be to put the pxxxx codes into Google. Usually one of the top results will get you to a site that gives you real info on the codes. The description the parts guy gives you doesn't mean anything.
Old Jun 17, 2014 | 02:35 PM
wagoneer's Avatar
This is what I was looking for Don and the codes showed up before I cleaned my air filter.
https://www.chevyhhr.net/forums/ss-s...ldering-47349/
Old Jun 17, 2014 | 03:36 PM
All of those codes aim directly at the MAF. Each one of them has MAF as a cause, implicitly if not explicitly. So fouled MAF or faulty wiring is the place to start. Then move onto the other possibilities.
BTW there are quite a few threads about the lower TMAP.
Old Jun 17, 2014 | 05:24 PM
Sorry if I sounded short, I was at work and using my semi smart phone. My fingers are way too fat for that tiny screen.
drummerboy0088
2.2L Performance Tech
19
Feb 10, 2015 12:25 PM
LuckyLadySD
Jun 12, 2014 02:09 AM
Michael20832
2.0L Performance Tech
Jul 8, 2009 05:16 PM
saltyfishguy
Apr 1, 2008 07:22 PM
