Any info on atk motors?
I read the ad for that engine. Seems it is the European version of the LNF and not a direct swap in engine. There are several parts on that engine that would need to be swapped with your old engine. For one, exhaust manifold is noted as being different between the 2. Read some of the reviews that note some other differences.
Other than that, seems like a great price.
Thank you guys
That is what failed on the last new motor (gm replacement)
And maybe I will use the stock turbo on my 2.2 panel with over 205k on her it may be time to build a 2.2 for it.
