Chevy HHR Network
-   HHR SS (https://www.chevyhhr.net/forums/hhr-ss-45/)
-   -   Bleeding Master Cylinder & ABS (https://www.chevyhhr.net/forums/hhr-ss-45/bleeding-master-cylinder-abs-63392/)
tiapetra Sep 14, 2020 12:11 PM
Originally Posted by tiapetra (Post 901121)
Here is a cost effective pressure bleeder if you are into the DIY stuff. Of course scanner with abs capability helps too.
https://www.amazon.com/Motive-Produc...51780138&psc=1
They work very well
You have to be very gentle with the brake fluid so as not to create microscopic bubbles which will collect into larger ones in your system later on. Brake fluids are bad about that.
Comes in handy for refreshing the fluid every couple years.
Originally Posted by Oldblue (Post 901122)
The Scan II tool is required for proper ABS bleeding of the brake fluid.
I bolded it for ya :thumb:
Oldblue Sep 14, 2020 12:38 PM
Thank you.
Pretzel Oct 9, 2020 10:14 PM
I just bought the Autel MAXI pro scanner. I have to bleed the ABS on my SSR. I will see if it supports the HHR ABS too.
Go to 10min mark on video.
