boost reading question
I have a question for any one that has any ideas......ADM sent me a Aeroforce scan gauge to try out, it reads boost but only to 22.7 psi....when logging with HP it will only read to 255kp = about 22.5 psi....the boost gauge in the hhr will read up to 27 psi...logging on the dyno we see the same or pretty close to what the in car gauge reads.....So my 10000$ question is were does the gauge get its reading from...its electronic so theoretically they all should be the same.
) to get a "real" measure. BTW, I think that's a typo above... 255kpa is about 37# of boost. The conversion factor between kpa and psi is .14503773773020923.
Boost Pressure (psig) = MAP (psia) - BARO (psia)
So, at sea level a 2.5 Bar MAP sensor will only read 22.29 psig
The LNF PCM code limits boost to 255 kPa.
The gauge displays baro corrected boost pressure and will not read absolutely correct because of BOV control and surge. Now, depending on how you log boost in HPT you will probably see a different reading that is hard to pinpoint. The HPT help file offers a formula to convert MAP to boost, but it uses a 14.5 psia atmospheric pressure constant that is probably not accurate for your altitude.
Your not going to see anything consistantly over approximately 22.5 psig, the turbo simply runs out of steam and the PCM code prevents the BOV from controlling anything over this.
How are you monitoring boost on the dyno?
