Build an HHR SS
You're probably correct PDW23....
The software is sub-standard as introduced. Some items are missing, some are incorrect. For example.....
while building your car, the manual trans is the default. But if you scroll down and select the remote start option, it automatically selects the automatic trans, WITHOUT DELECTING THE DEFAULT SELECTION OF MANUAL 5- SPEED. So when you go to summary you have both transmissions selected.
But, the dealers online order system should be up to date and provide the pricing and option combinations available.
.But, the dealers online order system should be up to date and provide the pricing and option combinations available.
Here is the window sticker on the black SS with standard transmission and locking differential that we currently have in stock. I am guessing Chevrolets web site needs to be corrected on the limited slip differential. Too bad our IT guy didn't put a correct picture with it, since it is such a HOT looking vehicle.
http://www.reliablechev.com/newcars/...DA73X78S624406
Accent Stripes?
Does anybody have any idea what the accent stripes look like? 17A - Single Smoke Accent Stripe (17A) $0.00 47A - Double Smoke/Smoke Accent Stripe (47A) $0.00 49A - Double Silver/Silver Accent Stripe (49A) $0.00 96A - Single Silver Accent Stripe (96A)
