Clutch smell
This is my first post (actually technically my second as I just replied to the transmission noises thread). I am the recent proud owner of a 5 speed black SS, probably the only one in Newfoundland, Canada. My satisfaction rating with this vehicle is about 80% but one issue concerns me. I'm getting a burning clutch smell on occasion. It has happened 2-3 times when revving the engine and slowly releasing the clutch when backing up an incline. Any remedy for this and can 1 or 2 severe occasions permanently damage the clutch? Thanks!
If you slip the clutch excessively, this is normal. To prevent this, don't slip the clutch; get on and then off quickly. A few instances of minor clutch slip won't hurt the clutch. Now, if you do this on a regular basis you will shorten clutch disc life and potentially warp the flywheel.
They tend to be a little smelly when they're breaking in anyway. You didn't damage it but the more kind you are to it the longer it will last (obviously).
Originally Posted by 405HP_Z06
(Post 288700)
Congratulations on your purchase BTW. What colour is it? |
Originally Posted by Canuck
(Post 288720)
Thanks for the replies. Seems like I should refine my driving techniques, especially when backing up on hills. A heavier duty clutch, however, would have been nice from GM.
yeah dont do that to often because you will glaze the clutch and will need to replace cuase it will slip after that
Originally Posted by jerSSey HHR
(Post 288758)
his post indicated black
Don't rev the engine. only need to give it slight gas and let out the clutch completely
Originally Posted by an08HHR
(Post 294050)
| All times are GMT -5. The time now is 04:05 AM. |
