Cooling Fan Running After Turning Car Off?
I have a 2008 SS with 90k miles. I drove it for a while today in sunny, 87 degree weather. Temp on dash was normal and I even scrolled thru gauges one time like always. Temp of coolant was 205 which is what mine always has run. When I got home, I put her in the garage and turned her off. I got out to do a couple of things in the garage and heard a fan running. I walked around to see what it was. It was the cooling fan on the HHR. It stayed on for about 2-3 minutes I would say before it cut off. Is that normal? I didn't remember hearing it do that before but just about every other time, I just go straight in the house.
So, is that normal? Do any of your HHR SSs do that too? |
Yes, normal. Donbrew(I think?) has posted the parameters before, can't recall what they are.
X2. Normal but I'll bet that it was over 205 when you turned it off. Like RJ, I can't remember the parameters for the temp to allow the fan to continue to run after shutdown. (something like 216 comes to mind but I could be wrong on that.
My fan has never run after shutdown but my operating temps are always around 187-189. Sometimes a little more if I let it idle a long time before shutdown. |
Yeah it did idle for a good bit when I first got home so we could move some cars around and put the HHR in the back of the garage. Then it was a slow crawl into the garage to park it. So I didn't look at the coolant temp at shutdown but I would say it could well have been over 205. Next time though, I will look at it upon shutdown.
The magic number is 284F! You have a problem.
Mine runs after shutdown, rarely. I've never been over 220 or so. There were other parameters, wish I could remember.
There is another place where it seems to say 230F. The entire section seems to have been copied from a different car though, lots of discrepancies.
Welcome to the site, a 2008 , have you ever changed the Dexcool, changed the thermostat?
if so , which thermostat did you use? it might be time to drain the coolant. Someone , changed to a better radiator. Age of the coolant is key, after it gets overheated , it crystallizes |
(Post 869451)
2010 SS 60K on the clock. |
Originally Posted by Oldblue
(Post 869465)
Thanks. |
