Excessive Timing Noise
Old May 30, 2025 | 05:25 PM
DawsonHHR's Avatar
Hello, this is my first time posting on the forums. I currently have a 2008 HHR SS w/ 147,698 miles on it. I recently had preventive timing maintenance done to it. I had the mechanic do the VVT sprockets and solenoids, guides and tensioner along with a new water pump. So, when I picked it up from the shop, I instantly heard a new whining sound coming from the timing side of the engine. I didn’t really think anything of it at the time, I shrugged it off as thinking it would eventually get quieter as I put more miles on it. 750 miles later, it sounds the exact same. So, is the whining noise normal and eventually will go away or was something not done right? The whining correlates with the RPM’s as in the video. Thanks
File Type: mov
Old May 30, 2025 | 06:25 PM
greg8453's Avatar
What brand parts did they use?
Old May 30, 2025 | 07:12 PM
DawsonHHR's Avatar
Cloyes
Old May 30, 2025 | 07:29 PM
Oldblue has a theory about the water pump tool not holding the sprocket inn the correct alinement that causes the whining. I blamed the pump I got and reyurned it the reinstall did not whine.
Old May 30, 2025 | 08:05 PM
Seems obvious that a new timing chain was installed, but please confirm.
Was a new balance shaft kit installed? Were either of the crankshaft sprockets removed or replaced? Was a new crank pulley bolt used, pulley installed on the keyway properly and torqued to spec?
Old May 31, 2025 | 04:49 AM
PulpFriction's Avatar
The water pump tool shouldn't be needed with a complete cover-off chain job, right? But excessive chain tension due to incorrect installation of either tensioner can cause noise.
Removing the valve cover to inspect the cam chain and front guide would be a start.
Old May 31, 2025 | 07:16 AM
It is plausible that it could be as simple as the timing chain tensioner wasn’t engaged. Did your mechanic change the balance shaft chain sprocket on the crankshaft? It is very different from the one contained in the Cloyes kit 9-4202s this maybe the source of the noise. Hopefully he didn’t toss the OEM, cause it’s obsolete. No longer available.
Old May 31, 2025 | 10:04 AM
I just got around to looking at the MOV that is the whirring I had from the water pump.
Old May 31, 2025 | 10:08 AM
I’m sticking to the SS , LNF issues. Very different from the 2.2 or 2.4 engines. I don’t know why but they are.
Old Jun 4, 2025 | 12:03 AM
DawsonHHR's Avatar
Sorry for the long wait to respond, but I believe he left the balance shaft sprocket alone. Does the tensioner have to be “reset” on the LNF after doing either a water pump and/or timing job? If so, I’m convinced that he missed that step and now there is excessive tension on the chain causing the noise.
