f35 mu3 transmission
Ok, my 2010 hhr ss has a f35 mu3 but does not have an lsd. I did get a 2006 cobalt f35 mu3 with lsd for a good price. I am having a problem locating information as to model I should buy the new clutch for. I was going to use the balt transmission as it is because it is in good condition and swapping out differentials is such a pain in the behind. Most clutch listings say the two use different clutch kits although I have found some that say they are the same. Anybody know for sure?
Search TTR and ZZP sites, they both should shed some light on this
http://www.turbotechracing.com/produ...dCategory=5615 https://zzperformance.com/ecotec/tra...rivetrain.html |
2006 Cobalt was the supercharged engine, correct ? That may be the reason for the 2 different clutch kits you're seeing.
Since the turbocharged HHR put out more HP and torque, it may have had a little stronger clutch from the factory than the Cobalt did. |
