Fuel in oil (a lot) with new LDK motor
Old 05-27-2017, 01:52 PM
HHRssrfun's Avatar
Originally Posted by Oldblue
Are they gas soaked! The combustion chambers should be full of fuel and the fuel level in the gas tank go down accordingly
Looking forward to checking them out.
HHRssrfun is offline
Old 05-28-2017, 12:33 PM
Cat Man HHR's Avatar
I don't think you should go overboard. Fuel into the crankcase points to the fuel pump before injectors.
An injector would give you some type of miss or poor performance. Maybe not even idle smoothly.
Change that part out with the oil and monitor the oil level from there.
Did the oil light come on at any point?
Cat Man HHR is offline
Old 05-28-2017, 03:10 PM
HHRssrfun's Avatar
Cat man thanks for the advice. Just finished the Indy 500. Out to the shop to check plugs. I never did get a miss or code and it idled just fine. So I am hoping that the HPFP was the problem. It doesn't smell like fuel as much too. It has fresh oil now.
I will update on the condition of the plugs and thanks for all the help.
Old 05-28-2017, 05:02 PM
HHRssrfun's Avatar
Ok, all 4 spark plugs looked great. Tan and gapped to 33 thousands.
And no fuel smell. Looking more like the problem was the HPFP and not the Injectors
I will update if anything changes.
Old 05-28-2017, 05:29 PM
Don't reinvent the wheel. Go with what is logical.
Old 05-28-2017, 09:39 PM
Technical Moderator
Don't ever touch the whisker on a Iridium plug with anything! Even checking the gap can damage them.
donbrew is online now
Old 05-29-2017, 12:44 PM
HHRssrfun's Avatar
Too late. But didn't hurt them. Runs great. I never had a problem with the iridium plugs in my Ducati. Just need to be gentle.
Old 06-17-2017, 06:04 PM
How's this issue going, Randy?
RJ_RS_SS_350 is offline
drummerboy0088
06-12-2017 12:28 PM
Powermizer
2.0L Performance Tech
210
04-11-2017 02:57 PM
JeramieJJ
03-24-2017 08:44 AM
Tyler
06-28-2016 11:42 AM
xzombiex66
04-06-2008 11:34 AM
Quick Reply: Fuel in oil (a lot) with new LDK motor
