Chevy HHR Network
-   HHR SS (https://www.chevyhhr.net/forums/hhr-ss-45/)
-   -   Fuel Pressure Issue (https://www.chevyhhr.net/forums/hhr-ss-45/fuel-pressure-issue-63993/)
nfuller20 Jan 10, 2021 06:35 PM
Fuel Pressure Issue
1 Attachment(s)
A friend of mine has a 2008 SS manual with a few mods thrown on. He's been having a misfire/unsteady idle problem. The video is the best way to understand the low side fuel pressure. What's causing such a weird erratic fuel pressure?
Oldblue Jan 10, 2021 06:46 PM
A failing intank fuel pump. Corrosion in the fuel lines and or dirty fuel injectors. Just to confirm what air filter is he running? It could be time for a new one.
nfuller20 Jan 10, 2021 06:53 PM
Fuel pressure stays extremely steady after shutting off, so I don't think there's a leak, and the sound in the video does seem to correlate with how the fuel pressure act though.
Oldblue Jan 10, 2021 06:55 PM
The video wasn’t that easy to see, but if that needle is bouncing the fuel pump is toast.
nfuller20 Jan 10, 2021 07:02 PM
Yeah it was just moving too fast for the camera to catch it! Do you mean the in tank or the mechanical pump?
Edit: Nvm you meant in-tank pump
donbrew Jan 10, 2021 11:42 PM
Could be either. That noise would lean me toward the mechanical.
RJ_RS_SS_350 Jan 11, 2021 09:22 AM
I get "can't open file"
firemangeorge Jan 11, 2021 09:25 AM
Doesn't matter Randy. Bad video. Can't see the needle on the gauge and the sound doesn't tell you much.
Here's a frame shot from the video.
https://cimg1.ibsrv.net/gimg/www.che...0b8971f3c8.png
donbrew Jan 11, 2021 09:44 AM
As I understand it the High pressure is variable. I would check the low pressure pump by running it with the engine off bypass the relay because it will only run for a few seconds.
