HHR SS approach angle / ramps
Old Aug 26, 2009 | 05:57 PM
1Panel2NV's Avatar
Originally Posted by Jeff®
I use a 2x10 and a couple bricks.
That doesn't sound very safe lol. Hope you don't get under the car like that.
Old Aug 26, 2009 | 06:31 PM
asanti's Avatar
Nah, he must live his life "One Brick At A Time".
Allex
Old Aug 26, 2009 | 09:19 PM
SSROADSTER's Avatar
ramps not needed.......
you do not need ramps to change the oil on the SS, you can get to the oil drain plug by simply lying on the ground......easiest oil change ever of any vehicle that I have owned.....
Old Aug 27, 2009 | 05:52 AM
hyperv6's Avatar
I don't know about that. Have you seen how thick some HHR owners are?
Old Aug 27, 2009 | 07:06 AM
Jeff®'s Avatar
Easiest change ever yes, but you must be very, very thin with long arms! I need the bricks and board.
Old Aug 27, 2009 | 03:23 PM
Snoopy's Avatar
After a couple of DIFFERENT efforts in ramps and methods to work under my vehicles, this is FINALLY the solution I came up with.
Notice I still needed to construct "ramps" to clear the undercarriage of my cars while driving onto the hoist. The minimum/collapsed hoist height is about 5.5 inches....without the ramps, part of the undercarriage of the HHR drags on the hoist....the Vette will not clear it at all.
Excuse the mess.....my "Man Cave" is currently under construction.
Old Aug 27, 2009 | 07:13 PM
redradt25's Avatar
Dude, you have a lift, not ramps!! Holy crap thats awesome. Anyway, I use the plastic ones from AutoZone that say "FOR LOW PROFILE VEHICLES" on the ramps. They work fine; however, your front lip still just barely touches the ramps so I took tie wraps, and took two peices of very small plywood (apprx. 8 x 8) and tie-wrapped the two pieces at the tip of the ramps (drilled holes). No problems now. The pieces of wood just stay attached.
Old Aug 27, 2009 | 07:32 PM
TomsHHR's Avatar
Someone posted another "dead thread" about 2 x 8 ramps a year or 2 ago.
Old Aug 28, 2009 | 09:52 PM
ORGELBAU's Avatar
I just place a piece of 2" x 12" in front of each Rhino Ramp and drive up. The wood raises the front end of the SS just enough to clear, allowing me up the ramps. I've never had an issue with slipping and it cost me virtually nothing.
Old Aug 29, 2009 | 10:10 AM
Neogenic's Avatar
Originally Posted by stephenm
having done towing for many years, i loaded a ferrari on a flatbed with 4 flat tires.
my trick was to lay blocks of wood down in front of the wheels and up to the ramp
so if you put a 2 or 3 foot piece of 2X4 between the tire and the ramp, it should lift up the front high enough to clear the ramp. if not put a thicker piece of wood after the 2x4 and before the ramp to make a step sequence
That was good advice. I am going to remember that.
