HHR vs. Cobalt - Parts
Will the downpipe for a Cobalt T/C fit on my HHR SS T/C? Since both cars use the same platform, is the complete exhaust system interchangeable between the cars? Do they both use the same motor/transmission mounts?
You might want to give Josh a shout at OTTPerformance. I bought their sway bar and Pedders springs, both listed on their site for a cobalt SS. Talking to Josh, he said lots of parts are interchangable. He could give you the straight anwers you're looking for. "Moon"
The down pipe fits for sure, I had a ZZP catless down pipe I took off and sold last week and just installed the ZZP spun cat down pipe yesterday. Both were for an 08+ cobalt SS/TC.
I wouldn't bother with the rest of the exhaust unless you just want one. It would be cheaper to have a muffler and/or resonator swapped out for the sound you want. There are dyno results on CobaltSS.net, where all the guy did was swap out a stock exhaust for a 3" aftermarket and he only gained 5whp & 7wtq on his Cobalt SS/TC (besides a different sound). A bigger exhaust isn't going to make huge gains unless you go to a big turbo, you can't argue with the dyno results. SO unless you just want an easier bolt on installation, for sound, having a new muffler and/or resonator welded on/off (depending what sound your going for) would be better. |
Originally Posted by racer-ray
(Post 474146)
Downpipe
Thanks HHRSSouth for the info. I'm gonna order a catless MPx pipe tonight. Will the catless downpipe make much sound difference? My car has 12k miles. As far as the rest of the exhaust, I'm not planning on replacing anything soon. I do have a Spintec muffler on my Fiero that I may weld on. I also have a Mac muffler (a lot like a Flowmaster 40) that was part of a catback system on my '96 5.0 Explorer. I'll wait to see what sound changes occur w/the downpipe.
i say get get rid of all restrictions. with a catless 3in dp all the way back,you can pick up a good 15hp,untuned.
(Post 474327)
Be prepared, a catless downpipe on cold start up sounds like a angry lawn mower till its gets out of the warm up mode, then it sounds pretty sweet. |
Be careful, I see you have an automatic tranny. They are positioned about an inch farther forward and change the length of the exhaust system compared to a 5spd HHR. Not sure how that compares with a cobalt, but I would check it first.
Originally Posted by prod
(Post 474419)
Originally Posted by mightymouse
(Post 474336)
| All times are GMT -5. The time now is 01:45 AM. |
