Originally Posted by donbrew
(Post 950289)
Oil pressure gauge does not have anything to do with oil volume, unless it is completely empty. I know this from blowing an engine up by cross threading the drain plug.
If the light is on when the key is on engine off the wires are good. |
I still don't know why you you said that you checked the oil level by draining it. Is the dipstick missing?
(Post 950291)
So, the oil light does not illuminate when the key is on and engine off? If the engine is off there is no oil pressure, the light should be on.
Some folks just enjoy an array of analog gauges I'd venture.
For a street-able automobile though, an oil pressure circuit would be better served with a 'transducer'(?) sort of sending system, instead of a leak-prone plasti-line snaking into the cabin area. What I'm suggesting is quite a bit more expensive, and the 'engine side' sensor/sending unit -is- sort of sizable, and would need to be remotely plumbed & mounted. When you're working with an engine compartment as cramped as these, I'd advise sticking with a factory signaling light though. |
That's the stuff
That sort of sending unit & gauge style tends to be quite accurate if you can get it adequately plumbed. |
| All times are GMT -5. The time now is 08:15 AM. |
