Chevy HHR Network
-   HHR SS (https://www.chevyhhr.net/forums/hhr-ss-45/)
-   -   My latest addition of parts getting installed (https://www.chevyhhr.net/forums/hhr-ss-45/my-latest-addition-parts-getting-installed-23821/)
gcsd3742 Jun 1, 2009 03:01 PM
https://www.chevyhhr.net/gallery/fil...icsGT-K450.jpg
Turbonetics GT-K450: I will be adding more pics as Secret Services finishes it up.
PN 11259
MODEL GT-K 450
HP 375-475
Turbine Housing T3 .63 A/R 4 bolt
Compressor Inlet/Outlet 3.5'' / 2.0''
Turbonetics is proud to release the brand new line of GT-K turbochargers. The GT-K family has been designed for maximum performance utilizing the most advanced turbocharger engineering and components. This next generation of turbo units features special Map Enhancement Porting to allow the compressor wheel to operate at its maximum efficiency across a very broad rpm range. This variant of bleed air design, has precisely placed slots machined into the compressor housing to limit effects of surge when using large turbochargers on small displacement engines as well as providing additional air flow to make maximum horsepower at high boost pressure levels and across the entire rpm range. Aerodynamics is what separates the GT-K turbo line from the competition.
Equipped with the latest HP Compressor Wheels, designed to maximize efficiency at high boost pressures, and the F1 Turbine wheel, created to capture maximum exhaust gas energy and reduce back pressures, the GT-K family of turbos delivers unequalled performance. Turbonetics HP Compressor Wheels are made of 354 heat treated aerospace aluminum and are manufactured utilizing Hot Isostatic Processing (HIP) to allow these wheels to be incredibly strong. When paired with the Map Enhancement Porting of the GT-K compressor housings, these wheels flow huge volumes of air at high pressure ratios while still delivering a cool efficient intake charge.
The F1 Turbines are a new generation of 10 bladed, tall tip height wheels that allow you to turn up the boost without encountering dreadful backpressure issues. Made from 713C Inconel and balanced to Turbonetics exacting standards, these wheels match up with the HP Compressor Wheels to make the best turbocharger combination available. Turbonetics exclusive Black-Chrome Perma-Coating also comes standard for heat reflection away from the compressor housing to aid it lowering compressor wheel inlet temperatures and gives these units great looks to match their performance. Select turbo systems will also be able to be upgraded to the GT-K Turbos if so desired. Turbine housings will feature high temperature ceramic coating to trap exhaust gas energy inside the turbine housing for greater energy delivery and faster response time, as well as keeping the engine compartment temperatures low. Cooler under hood temps means more power potential from a cooler compressor intake charge.
Geoff Jun 1, 2009 04:21 PM
Very nice!!
damronjr Jun 1, 2009 05:49 PM
Sweet!
hyperv6 Jun 1, 2009 05:56 PM
Which Axle will break first?
gcsd3742 Jun 1, 2009 07:15 PM
I'm getting that fixed as well....
http://www.gatorracingaxles.com/
http://www.driveshaftshop.com/
skimike Jun 1, 2009 07:36 PM
axels wont break the tranny will first, I have personel knowledge. what does one of theese cost and where to get it installed, I would really love to have 375 to 400 hp. it would be great to get one of theese to run in the mid to low 12s. that way I could get mustang gts and cobras to eat dust.
crazysteve Jun 1, 2009 07:55 PM
you guys are not playing nice come and get me with the stock turbo. ;)
gcsd3742 Jun 1, 2009 07:56 PM
thought you didnt have one no more?
camaro98z28 Jun 1, 2009 08:09 PM
Thats some nice stuff dude. :)
gcsd3742 Jun 1, 2009 08:10 PM
Thanks guys
