My SS on Stance Coilovers
He didn't use a camber kit. You can adjust camber using the top mount.
The coilover spring is a smaller diameter than the stock spring, so you gain some clearance there, but you will still have issues rubbing the inner fender. With spacers, I bet he could run 17x9's with stretched tires to be hella flush lol
Bart - get a different catback or have it modified so you can level the back out. Don't run the coilovers in the winter, just change back to the stock parts. It doesn't take that long. Or buy a beater car.
