Chevy HHR Network
-   HHR SS (https://www.chevyhhr.net/forums/hhr-ss-45/)
-   -   Is this normal? (https://www.chevyhhr.net/forums/hhr-ss-45/normal-19172/)
foolmoon_design Oct 29, 2008 08:16 AM
Is this normal?
It is in the 30's here in Floridia the past couple of days, and I am only seeing a steady boost of about 8-10 PSI then it climbs wit the RPMs to 14-15 right before the shift, then back down to 8-10.........?????????
I am a "Newb"..... so is this the ECM regulating boost because of the ambient temperature? or have I finally been visited by the "lost vacumn" fairy?
Any help would be appreciated, before i decide to give up my car for a few days.
Intuition made me find what I thought were the vac hoses, and all seemed fine, I could be missing one or two......
crazysteve Oct 29, 2008 08:20 AM
how does it run....if it still runs ok i would say you are fine....colder denser air does not take as much boost to make the power.
foolmoon_design Oct 29, 2008 08:28 AM
It still runs well, I think problem is me! How are the mods comming?
hurst equipped Oct 29, 2008 09:58 AM
i just drove a brand new '09 ss auto and it does the same thing.
ts5p Oct 29, 2008 10:39 AM
1st and 2nd boost is limited around 5 to 10psi i think
3rd and 4th are still limited but not as much i have seen 16psi in the auto
this is most likely because they limit the HP in 1st and 2nd to 235
and in 3rd and 4th to 250
cannuck Oct 29, 2008 04:14 PM
boost runs off your exhuast gas, plus the computer has decided that 1st and 2nd gear cant handle the truth. thats why the tune has the answer
ts5p Oct 29, 2008 04:19 PM
what i do not get is if the trans can not handle the full power of the engine how is it gm is going to explain the upgraded tune when they finally release it
white heat Oct 29, 2008 04:35 PM
On pcm controlled boost, the boost is always lower in colder weather. Denser air molecules in colder air so less boost is needed.
