ok...this may be the question of the day!!!how do you....
how do you (auto drivers) use the Launch Control feature on your SS???
do you brake torque the trans and bring the r's up? or do you just put in that mode and go off idle? the second way is how I do most of my DashHawk testing, a few times I did brake torque to around 1200 rpm's or so...but usually just from off idle in that mode. I know it is so different from the 5-speed trans, but never have fully understood how it is or what is the correct way to use Launch Control with the Auto trans.. So any insight is welcome:smile: |
I like idle mode in I gear :2cents:
I my self would like the answer to this one! .....personally, I have tried the foot on the brake, give it gas method and usually just get some tire spin......I have gone as far up as 3500 rpm before letting off... seams the best for me is small break load to full pedal... but, I am in the dark as to its actual working, and the owners manual is real vague
