P0101
Originally Posted by ssdivin
(Post 556318)
can someone tell me where each hose goes
https://www.chevyhhr.net/gallery/fil.../3/4/2/010.JPG Can someone tell me the name of the part and where to find it ive replaced everything else and still can not build boost ive searched the part number and cannot find anything about it |
Looks like the turbo boost sensor, perhaps RJ or FMG can positively identify it.
I can't find any reference to that part number.
The part in the picture is the bypass solenoid, GM P/N 12653854. Another number is 12634111, superseded now by 12633355. There are several reasons why you can't generate boost. What code(s) are you getting? |
RJ , that P/N doesn’t show up , possibly obsolete?
(Post 884220)
The part in the picture is the bypass solenoid, GM P/N 12653854. There are several reasons why you can't generate boost. What code(s) are you getting? |
I was just editing
Probably a vacuum/boost leak.
Intercooler plastic ends, charge piping or clamps, vaccum tank, the list goes on and on... What mods do you have? |
(Post 884225)
Intercooler plastic ends, charge piping or clamps, vaccum tank, the list goes on and on... What mods do you have? Debating doing the vaccum tank delete to see if that is what is causing the issue |
Do not do a vacuum tank delete. The system has to have a reserve supply of vacuum for the turbo system to operate correctly. Under a heavy load, the engine produces minimal or no vacuum. Without a tank to hold that reserve, the system has nothing to draw from when the engine is not producing a vacuum.
(Post 884233)
| All times are GMT -5. The time now is 04:34 AM. |
